HR21
Jan 21, 2018Aspirant
Cannot connect my Carrier Infinity Thermostat
I have a Carrier Infinity Thermostat that used to connect to internet with no problems on my previous 2 routers (Previous Century Link and Netgear routers). Now, it cannot connect to my Orbi, despite...
DarrenM
Jan 23, 2018Sr. NETGEAR Moderator
Have you checked if it needs to be connected to a certain band at all times some smart devices do not like mesh networks.
DarrenM
- DavidShawPJan 24, 2018Star
I had that problem with my Ring devices. It turns out they are on 2.4 GHz only and need a channel between 1-11. I set the channel manually and it works well now. You could try that.
- HR21Jan 24, 2018Aspirant
Thanks for the tip. I tried to maulay select the 2.5G band to channels 1, 6 and 11.. tried all 3 but did not work.
One more thing I need to change in my original post. I actually cannot see it connected ever on my device list when I log in to my router.
