Atlas2010
Apr 29, 2020Tutor
Cannot connect Orbi RBR50 to Viasat modem RG1100
Has anyone been able to connect Orbi RBR50 to Viasat modem RG1100? Please let me know settings on Orbi and Viasat. Any help appreciated. Thank you.
Apr 30, 2020Guru - Experienced User
I would contact Viasat for help and information on using external routers with there system. SAT can be picky about this. I remember having problems when I had SAT years ago.
Be sure there modem/router isn't using 192.1681.1 for an IP address.
If the modem has a built in router, This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Thank you.
Atlas2010
Apr 30, 2020Tutor
Hello FURRYe38,
I have the Viasat modem in Bridge Mode, but still having problems. Viasat has no idea how to set up. How do I put Orbi in Router Mode?
- FURRYe38Apr 30, 2020Guru - Experienced User
Did you power OFF the SAT modem for 1 minute then back on then factory reset the RBR and walk thru the setup wizard using a wired PC and web browser pointed at 192.168.1.1?
Be sure your using a good quality LAN cable between the modem and RBR. CAT6 is recommended.
- Retired_MemberApr 30, 2020
Atlas2010 wrote:
Hello FURRYe38,
I have the Viasat modem in Bridge Mode, but still having problems. Viasat has no idea how to set up. How do I put Orbi in Router Mode?https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point
Was mentioned already. :smileyvery-happy:
did the OP read it????:smileytongue:
The RBR should be in router mode by default unless you already configured AP mode. You can use the same menu setting to set the RBR back to router mode if it's in AP Mode. Or factory reset the RBR and walk thru the setup wizard with the RBR connected to the modem.
Let us know how it goes.
Atlas2010 wrote:
Hello FURRYe38,
