Atlas2010
Apr 29, 2020Tutor
Cannot connect Orbi RBR50 to Viasat modem RG1100
Has anyone been able to connect Orbi RBR50 to Viasat modem RG1100? Please let me know settings on Orbi and Viasat. Any help appreciated. Thank you.
Atlas2010
Apr 30, 2020Tutor
Hello FURRYe38,
I have the Viasat modem in Bridge Mode, but still having problems. Viasat has no idea how to set up. How do I put Orbi in Router Mode?
Apr 30, 2020Guru - Experienced User
Did you power OFF the SAT modem for 1 minute then back on then factory reset the RBR and walk thru the setup wizard using a wired PC and web browser pointed at 192.168.1.1?
Be sure your using a good quality LAN cable between the modem and RBR. CAT6 is recommended.
