Lars157
Dec 06, 2017Aspirant
Cannot connect orbi satelite
Dear community, I have lost connection with my orbi ac3000 satelitein the manual. According to the manual, I must syncronize with the satelite, when the white light is still, but it keeps flashing ...
Lars157
Dec 15, 2017Aspirant
Yes, I have already done that. My network is up and running, but I still cannot connect with the satellite. Do I have to change the ip-address for the satellite, and if so, how do I do it?
Regards Lars
DarrenM
Dec 18, 2017Sr. NETGEAR Moderator
I would try to factory reset the satellite then try to sync the unit again.
DarrenM
