rkr3orbi
Nov 18, 2018Aspirant
Cannot connect Orbi satellite
I recently purchased a refurbished Netgear Orbi RBR50 System with on RBS50 satellite off Ebay. (I actually purchased two systems, one of which is working perfectly, and which I've gifted to someone)....
michaelkenward
Nov 18, 2018Guru - Experienced User
rkr3orbi wrote:
To avoid a conflict with your Internet service provider, your Orbi router's IP address was updated to 10.0.0.1"
- Which is fine, as my modem is set to 192.168.1.1, and it's not something I can fiddle with.
This suggests that you are trying to add an Orbi in router mode to an existing router. If that is the case then you might do better to put the Orbi into access point mode before you add it to your network.
