rkr3orbi
Nov 18, 2018Aspirant
Cannot connect Orbi satellite
I recently purchased a refurbished Netgear Orbi RBR50 System with on RBS50 satellite off Ebay. (I actually purchased two systems, one of which is working perfectly, and which I've gifted to someone)....
Nov 21, 2018Guru - Experienced User
Are you looking at the top of the satellite after you set it and seeing the top led flash WHITE, then pulsate WHITE Slowly? If not, then it's possible the satellite is bad and needs to be replaced.
- rkr3orbiNov 22, 2018Aspirant
No, that's the thing, it flashes white continuously, ON-OFF -- never goes into pulsating mode. (I know the difference; the main router did the flash-then-pulsate).
- FURRYe38Nov 23, 2018Guru - Experienced User
Possible that the satellite is bad and needs to be replaced if it's not getting to the pulsating WHITE mode. I would contact NG support and ask for help on this.
