  • FURRYe38's avatar
    What FW is currently loaded?
    Is the Orbi system operating in Router or AP mode?
    Try the PS4 wired to the Orbi router?
    What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
    What WPA security modes are you using? Try WPA2 and AES only.
    MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
    Disney Circle: https://community.netgear.com/t5/Orbi/WARNING-Firmware-2-2-1-210-is-junk/m-p/1667485/highlight/true#M45926
    If you updated to recent FW v.210, try enabling Daisy Chain. Some have mentioned that this seems to be working in reverse order, enabling means disabled actually.
  • Blanca_O's avatar
    Blanca_O
    NETGEAR Employee Retired
    Hi jespervalex
    We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
    Blanca
    Community Team
