gotowiec27
May 25, 2022Aspirant
Cannot connect RBS10 with LBR20
Hi everyone, I've got an issue with my recently purchased RBS10 satellite. I can't make it to synchronize/connect with my LBR20 router. I bought it after confirmation from the below post, that tho...
KevinLiT
May 25, 2022NETGEAR Moderator
Hi gotowiec27,
Welcome to the NETGEAR community!!
The RBS10 is compatible with the LBR20.
Please ensure that your LBR20 is running firmware v2.6.5.32.
Best,
Kevin
Community Team
gotowiec27
May 26, 2022Aspirant
Hi KevinLiT ,
My LBR20 is running the latest software (V2.6.5.32).
Still, I can't connect it. Additionally, I don't see the wifi network from the satellite.
I`ve tried to reset it using the button on the back, but without success. Same for the QR code from the label. My smartphone asks me if I want to connect to "ORBI53" and then it says, that either it cannot connect or cannot find it.
- plemansMay 26, 2022Guru - Experienced User
If its new, you should have 90 days of free support that you can call and talk to someone. it might be faster.
To get a hold of support. Click on "MyNetgear" at the top.
Register an account (or login) and then the device.
From there you can start the support process. Keep in mind that its only free for the first 90 days. - KevinLiTMay 26, 2022NETGEAR Moderator
Hi gotowiec27 ,
Thank you for confirming your LBR20 firmware.
Please check your PM so that I may assist you further no this issue.
Best,
Kevin
Community Team
