frocha
Feb 11, 2020Aspirant
Cannot connect to 5G network on Orbi 3000 from Windows or Mac
I have an Orbi AC3000(RBK53). I'm trying to connect to the 5G network from both a Macbook and a Windows 10 laptop. On both laptops I can see three networks: ORBI22, ORBI22_2GEXT, and ORBI22_5GEXT....
frocha
Feb 12, 2020Aspirant
Firmware: RBR50 v2.3.5.30
Router is from Spectrum. It is a E31U2V1, DOCSIS 3.1 eMTA
Orbi is operating in Router mode
House is approx 2400 SQFT
Satellites are less than 30ft from base
2.4Ghz is channel 6
5Ghz is channel 44
No other wifi signals nearby
CrimpOn
Feb 12, 2020Guru - Experienced User
So, when you connected to the "ordinary" ORBI22", which channel did the Orbi say it connected at? (2.4G or 5G)?
- frochaFeb 13, 2020Aspirant
Hmmmm. I may not have a problem. I signed onto the Orbi router "orbilogin.com" and it appears that while everything I have is signed onto the "ORBI22" network, my devices have a mix of 2.4G and 5G connections. Someone told me that Orbi is dual-band and will select the most appropriate network to connect to??? So maybe I don't have a problem?
- tomschmidtFeb 13, 2020Virtuoso
Devices will connect to the best WiFi signal. Many older devices only support 2.4GHz, so they cannot and will not use the 5GHz band. Devices that support both bands may connect to the 2.4GHz since it can travel further distance than the 5GHz signal.
- schumakuFeb 13, 2020Guru - Experienced User
ORBI22 is a randomly factory default network name, Orbi does use one name/SSID for 2.4 GHz and 5 GHz. So no problem, indeed.
