Deihmos
Oct 28, 2018Guide
Cannot connect to alarm using ipdatatel
I just purchased the Orbi and having issues connecting my alarm wireless adapter from ipdatatel. The device uses 2.4 ghz network but for some reason fails to connect to this router. It connects fine ...
- Oct 29, 2018
I was able to solve this issue by disabling WMM (Wi-Fi multimedia) settings. The router connected fine to the alarm with prior firmware so I don't know why this has happened. Now I have to decide if I should keep or return to the store. Pros are the connection speed is really good but the cons are the router seems buggy and you can't disable auto-update. Also there should be a way to have seperate name for 5G and 2.4G.
Deihmos
Oct 29, 2018Guide
Oct 30, 2018Guru - Experienced User
How interesting. Thanks for letting us know. Seems like there is a problem with WMM and your device. Something NG and your devices Mfr should review. WMM should always be enabled for best wifi performances.
Understand about autoupdate. There should be an option to disable it. Would be less hassle.
As for making separate SSIDs, the main function of MESH is to have a single SSID thats automatically handled by the MESH system to connect devices too. This is how MESH is intended to work and designed across all MESH Mfrs. Wouldn't be MESH if it was otherwise.
Good Luck.
- DeihmosOct 30, 2018Guide
My Asus router has this enabled and it works fine with my alarm so this issue is with NG. I found a guide to rename the 5G network. The router sometimes connects my devices to 2.4GHZ which results in terrible performance when using my streaming devices.
- FURRYe38Oct 30, 2018Guru - Experienced User
Ok well if that works for you. IT's not the intended used or design for Orbi and not supported.
If it works for you then use it.
Just be cause it works on a different router doesn't mean it's all NG fault. Problems still could be with the wifi drivers on this particular device that maybe incompatible with newer generation wifi drivers that are on the Orbi. Again, something that NG and the devices Mfr will need to look at .
Good luck.
