zvikagutkin
Nov 26, 2019Aspirant
cannot connect to internet when ups is active orbi20
Hi , I have the orbi20 with 2 sattelites . The orbi is connected to a modem with cable . the modem and orbi router connected to UPS . When there is a power outage the modem and orbi getting power...
Nov 26, 2019Guru - Experienced User
What is the Mfr and model# of the ISP modem the NG router is connected too? Buit in router here by chance?
I would not include the RBS in with any emergency batter backup configurations as this would draw more power from the UPS or a UPS. The only item you need if you want to provide some wifi internet access while the UPS is engaged during a power outage is the ISP modem and the base RBR only.
Possible the UPS may not be delievering enough power when it's engaged. To test this out a bit more connect the ISP modem and RBR to a power strip thats connected to a wall out let. Then simulate a power outage by turning off the power strip for 30sec to a 1minute. Then power it On. Check the RBRs top ring LED behavior. Does it pulsate or flash WHITE or does it turn BLUE then turn OFF. OFF means the RBR is working normally.
https://kb.netgear.com/31030/What-do-the-LEDs-on-my-Orbi-mean
What are the results for this?
- zvikagutkinNov 26, 2019Aspirant
v2.3.5.26
technicolor TG789vac v2
it's a modem router
This is exactly how it is , only the modem and orbi base connected to the UPS.- FURRYe38Nov 27, 2019Guru - Experienced User
What mode is the ISP modem working in? Modem only mode or Router mode?
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly. Then use the Orbi router in router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopPossible the UPS may not be delievering enough power when it's engaged. To test this out a bit more connect the ISP modem and RBR to a power strip thats connected to a wall out let. Then simulate a power outage by turning off the power strip for 30sec to a 1minute. Then power it On. Check the RBRs top ring LED behavior. Does it pulsate or flash WHITE or does it turn BLUE then turn OFF. OFF means the RBR is working normally. What is the result of doing this simulated power bump test?
zvikagutkin wrote:What Firmware is currently loaded?
v2.3.5.26
it's a modem router
This is exactly how it is , only the modem and orbi base connected to the UPS.- zvikagutkinNov 28, 2019AspirantHere is a video that show the issue
