Elcdavis
Dec 05, 2019Aspirant
Cannot connect to orbi WiFi
Move to a new home and now I am trying to reset up our Orbi system. The RV is connected to the modem through the proper ports. When I go through the set up it says would you like to connect to the Orb...
Dec 05, 2019Guru - Experienced User
Manually connect you mobile phone to the wireless network.
Walk thru the setup wizard with a wired or wireless connected PC/Laptop and a web browser.
You can change the SSID name and PW as well, which is recommended. The SSID name can be anything.
