Vizard's avatar
Vizard
Cannot connect to Satellie (Router RBR50 with Satellite RBS50)
Hello,
I cannot connect to my satellite. I have a RBR50 Router and RBS50 Satellite. The firmware on the router is V2.7.3.22 and on the satellite is V2.7.2.104. The satellite has red flashing light near the power input. I have tried sycing but it does not work. When I log into http://orbilogin.com/, I cannot see any way to update the firmware on the satellite. When I go to Manual update, my satellite is not in the list. Appretiate the help
  • CrimpOn's avatar
    CrimpOn
    Vizard wrote:
    Hello,
    The flashing red LED next to the power socket means the satellite is not working.  (Notice the euphimism "might need attention")
    https://kb.netgear.com/31030/What-do-the-LEDs-on-my-Orbi-mean
    If it is less than 1 year old, I would contact a forum moderator and request a warranty replacement.
    • Vizard's avatar
      Vizard
      Thank you CrimpOn . I bought the unit in Jan 2021. I contatced tele support, and there wasn't a solution. I've been recommended to rasie a support ticket, but have to pay subscription for techincal support which is a bit annoying.
      • CrimpOn's avatar
        CrimpOn
        That one year period is expiring soon. Can you send a private message to Blanca_O and ask how to get a warranty replacement. Maybe the method is to pay for a support incident and get a refund after they issue the RMA
