jaysam
Nov 08, 2019Aspirant
Cannot connect to the internet with Orbi RBK50v2
Trying to connect to the internet, using our Vodafone (NZ) router, Orbi is all on and good to go but cannot connect to internet. It can't be that hard! I have tried manually entering all the IP info...
cn8476
Mar 31, 2020Aspirant
Hi jaysam,
I have the same problem at the moment (Vodafone Ultra Hub + Orbi RBK20). What seemed to work best for you?
Cheers
Apr 01, 2020Guru - Experienced User
Is the Vodafone Ultra Hub the ISP modem or is this just a router? If it's just a router and you have a modem infront of the HUB device, remove this HUB router device and connect the RBR directly to the ISP modem.
What is the Mfr and model# of the ISP modem/ONT the NG router is connected too?
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try these other suggestions of the modem is a modem/router combo unit.
cn8476 wrote:I have the same problem at the moment (Vodafone Ultra Hub + Orbi RBK20). What seemed to work best for you?
Cheers
