StanDenman
Jan 20, 2023Aspirant
Cannot connect to this network
My desktop will not connect reliably to my orbi mesh. When I do get a connection it will drop many times a day - often maddeningly in the midst of important work. But my laptop, sitting on the very...
Jan 20, 2023Guru - Experienced User
What Orbi model system do you have?
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR and RBS🛰️ to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 🛰️
How is the system set up? Basic and Advanced Wireless settings?
What devices do you have connected? Brand and model?
Do ethernet connected device work?
StanDenman
This is a generic unresponsive answer. Read the post please.
