StanDenman
Jan 20, 2023Aspirant
Cannot connect to this network
My desktop will not connect reliably to my orbi mesh. When I do get a connection it will drop many times a day - often maddeningly in the midst of important work. But my laptop, sitting on the very...
Jan 20, 2023Guru - Experienced User
What Orbi model system do you have?
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR and RBS🛰️ to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite ‌‌🛰️
How is the system set up? Basic and Advanced Wireless settings?
What devices do you have connected? Brand and model?
Do ethernet connected device work?
StanDenman
Ridiculous that I cannot get a direct answer to a simple question here!!!
- michaelkenwardJan 21, 2023Guru - Experienced User
I agree that questions about square feet are a bit off topic – they annoy me too, like equally useless advice on the best cables to use – but there were several other questions that you failed to address that may well be behind the problems you see.
Unfortunately, we don't know what you have at your end. just two anonymous computers connected in some way to your router.
Only when you provide some details can any9one begin to guess what might be going on. Let's start with the boilerplate questions that are behind many of the issue that crop up here.
What firmware version do you have on the device?
A number is more useful than "the latest". (It may not be by the time people read this.) There can also be newer versions, or "hot fixes", that do not show up if you check for new firmware in the browser interface.
It might also help if you told people what the modem is in front of this router, if there is one. The make and model number could be useful. Is it, by any chance, also a router, with a set of LAN ports on the back?
The reason for asking is that a lot of people turn up here trying to put a router behind a modem that is also a router. That can complicate troubleshooting.I can think of other possible issues, but I wouldn't want to tax your patience any further.
Apologies for all the questions. But you can help people to help you by providing the information suggested in this forum's header:
Subject (Include model number and brief summary)
Model (Recommended - Helps the community give the best answers)
Body (Include additional detail including model version, firmware, OS and environment where relevant.)They are there for a good reason.
If you aren't prepared to deal with reasonable questions, most of which are known to be relevant from past experience, you are on your own.
