Kjors
Oct 28, 2020Aspirant
cannot connect vpn l2tp, orbi satellite
Hi all, I am have a problem with an orbi satellite. When connected to the satellite I cant coonnect to a vpn. When connected to wifi from the router itself the connection can be established. As g...
Oct 28, 2020Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
Is the RBS wired or wirelessly connected to the RBR?
- KjorsOct 28, 2020Aspirant
Updated to the latest firmware, RBR 40 : V2.5.1.22 and RBW30 V2.5.0.4
ISP modem/router (ZTE Experia Box v10), set to bridge mode. Wired to the orbi router (RBR40). The wall plug satellite is connected wireless, about 10 meters (33ft).
- FURRYe38Oct 29, 2020Guru - Experienced User
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopI would try option #2...put the modem back in to router mode and disable ALL wifi radios on the modem...
- KjorsOct 30, 2020Aspirant
I had option one build, its posible to switch to bridge mode. Build option 2 for testing. It has te same result.
Using/starting vpn:
- Connected wired to orbi router. Works
- Connected wireless to orbi router. Works
- Connecten wireless to orbi satalite. Does not work.
How would the network on the wan-side of the orbi router, infulence the network on the orbi statellite and not the orbi router itself?
