bdriessen
Apr 18, 2020Tutor
Cannot connect wireless with Sonos PLay 1 on Orbi RBK13
I have seen several topics on issues with Sonos and Orbi, but none of them helped me. I am unable to connect my Sonos Play 1 to my new Orbi network I have the RBK13 AC1200 with firmware V2.3.6.18 and...
- Apr 20, 2020
Hi bdriessen
Kindly update the firmware to v2.5.1.30. It fixes the compatibility issue with Sonos devices. Here's the release notes:
https://kb.netgear.com/000061840/RBR10-RBS10-Firmware-Version-2-5-1-30
Blanca
Community Team
Apr 20, 2020Guru - Experienced User
Are you using the same SSID name and PW on Orbi that you had use prior on your old wifi router?
- bdriessenApr 20, 2020Tutor
Yes. All other devices connected fine
- FURRYe38Apr 20, 2020Guru - Experienced User
Try to disable the wifi security temporarily on the RBR. Then try to connect the Sonos to the system. Does it connect at all?
Then re-enable WPA and TPIK. Does it connect any? Then try WPA2 and AES only...
- bdriessenApr 21, 2020Tutor
That did it! Many thanks.
