bdriessen
Apr 18, 2020Tutor
Cannot connect wireless with Sonos PLay 1 on Orbi RBK13
I have seen several topics on issues with Sonos and Orbi, but none of them helped me. I am unable to connect my Sonos Play 1 to my new Orbi network I have the RBK13 AC1200 with firmware V2.3.6.18 and...
- Apr 20, 2020
Hi bdriessen
Kindly update the firmware to v2.5.1.30. It fixes the compatibility issue with Sonos devices. Here's the release notes:
https://kb.netgear.com/000061840/RBR10-RBS10-Firmware-Version-2-5-1-30
Blanca
Community Team
Apr 20, 2020Guru - Experienced User
Are you using the same SSID name and PW on Orbi that you had use prior on your old wifi router?
bdriessen
Apr 20, 2020Tutor
Yes. All other devices connected fine
- FURRYe38Apr 20, 2020Guru - Experienced User
Try to disable the wifi security temporarily on the RBR. Then try to connect the Sonos to the system. Does it connect at all?
Then re-enable WPA and TPIK. Does it connect any? Then try WPA2 and AES only...
