cwj01
Sep 14, 2020Guide
Cannot disable Netgear Armor
Cannot disable Netgear Armor in Orbi App. Error message: "process is taking too long (more than 60 secs), Try again!!" This is very frustrating, because its preventing me from getting tasks d...
- Sep 15, 2020
Tried rebooting and still no luck, so I backed up my settings and did a hard reset.
Was able to disable it. I was reluctant in doing a hard reset because I thought I'd have to reconnect numerous devices, but the backup I did seemed to reconnect all my devices (so far). Thanks for everyones help!
Mstrbig
Sep 14, 2020Master
Did you follow these directions:
Connect your mobile device to Orbi router’s WiFi network.
Launch the Orbi app.
The Dashboard displays.
In the top-left corner, tap the Home or Cloud icon.
Note: The icon varies depending on your router’s settings.
Tap SETTINGS > Security.
If prompted, enter your NETGEAR account credentials and tap NETGEAR SIGN IN.
On the NETGEAR Armor page, tap the Enable NETGEAR Armor slider to turn NETGEAR Armor on or off.
Your changes are saved.
- cwj01Sep 14, 2020GuideFollowed those directions. Tried this numerous times. Got the same error message.
- FURRYe38Sep 14, 2020Guru - Experienced User
Try a power cycle OFF of the RBR for 30 seconds, then back on. Then try to disable Armor with in the Orbi app. If this fails, you'll need to factory rest the RBR and setup from scratch and then not re-enable Armor. I would make a back up of this configuration to file for safe keeping. Saves time if a reset is needed.
cwj01 wrote:
Followed those directions. Tried this numerous times. Got the same error message.- cwj01Sep 15, 2020Guide
