cwj01
Sep 14, 2020Guide
Cannot disable Netgear Armor
Cannot disable Netgear Armor in Orbi App. Error message: "process is taking too long (more than 60 secs), Try again!!" This is very frustrating, because its preventing me from getting tasks d...
- Sep 15, 2020
Tried rebooting and still no luck, so I backed up my settings and did a hard reset.
Was able to disable it. I was reluctant in doing a hard reset because I thought I'd have to reconnect numerous devices, but the backup I did seemed to reconnect all my devices (so far). Thanks for everyones help!
CrimpOn
Sep 14, 2020Guru - Experienced User
cwj01 wrote:Cannot disable Netgear Armor in Orbi App.
I've looked at other threads to no avail. People have mentioned reseting the router, but for me that is not an option.
When the app simply will not work, there appears to be no alternative but to reset the router.
Can you explain "that is not an option"?
- jesseinlaJul 17, 2022Aspirant
"This is not an option". Well, if you had many people connected to your WI-FI and the network could not be disrupted, then a FREAKING factory reset is NOT an OPTION" do you understand NOW? One should not have to factory reset for something so simple as to disabling a feature. Especially if I bought my RAXE500 for over $600. This kind of crap is bad for a company that chooses to ignore this situation.
