cwj01
Sep 14, 2020Guide
Cannot disable Netgear Armor
Cannot disable Netgear Armor in Orbi App. Error message: "process is taking too long (more than 60 secs), Try again!!" This is very frustrating, because its preventing me from getting tasks d...
- Sep 15, 2020
Tried rebooting and still no luck, so I backed up my settings and did a hard reset.
Was able to disable it. I was reluctant in doing a hard reset because I thought I'd have to reconnect numerous devices, but the backup I did seemed to reconnect all my devices (so far). Thanks for everyones help!
cwj01
Sep 14, 2020Guide
Followed those directions. Tried this numerous times. Got the same error message.
Sep 14, 2020Guru - Experienced User
Try a power cycle OFF of the RBR for 30 seconds, then back on. Then try to disable Armor with in the Orbi app. If this fails, you'll need to factory rest the RBR and setup from scratch and then not re-enable Armor. I would make a back up of this configuration to file for safe keeping. Saves time if a reset is needed.
- cwj01Sep 15, 2020Guide
- FURRYe38Sep 15, 2020Guru - Experienced User
Glad you got it disabled.
Be sure to visit the Armor forum for additional help and information regarding that app.
https://community.netgear.com/t5/NETGEAR-Armor/bd-p/en-home-armor
Enjoy. :smileywink:
- MstrbigSep 15, 2020Master
cwj01 wrote:Tried rebooting and still no luck, so I backed up my settings and did a hard reset.
Good News!
When all else fails, go back to the beginning and factory reset. Saves lots of frustration.
