JohnnyAz
Jan 19, 2019Aspirant
Cannot download
Cannot download anything after setting up this network today, firmware updated no other setting touched. I cannot log into the “ip” page either to check settings or change them, it requires a password...
JohnnyAz
Actually is RBR20 but I couldn’t find it in the prompted models
michaelkenward
Jan 20, 2019Guru - Experienced User
There is support for the Orbi WiFi System, including a manual, somewhere at the end of this link:
>>>> Orbi RBK50 | WiFi System | NETGEAR Support <<<<
I'm afraid I find it difficult to follow your first mesage.
What does that mean? What are you doing and what happens?
I cannot log into the “ip” page either to check settings or change them, it requires a password that’s not the netgear account one neither the classic “admin” “password” (as said in the instructions)
Login to what IP page and with what?
And what do you see that "requires a password that’s not the netgear account"? What Netgear account?
- JohnnyAzJan 20, 2019AspirantI cannot download means literally I can not download app updates, songs from
Spotify, mail attachments and so on; I searched ok the Internet for solutions and on the Netgear community i found some users suggesting to change this setting or that setting and I tried, but I cannot find any page in which to change these settings because i’m asked a “username and password” if I try to log into the classic “192.xxx.x.x” page and this username and password is not the one I set up while registering my RBR20 to the netgear community;
All of this to say, I found on this community other threads that suggest I may have to change some firewall settings or security settings or things like that but I can not even find a way to reach those settings to change them; I hope i’ve been clearer on this message given the fact that writing in English about networks and stuff is kinda difficult cause i’m Italian! Have a good day- ekhalilJan 20, 2019Master
JohnnyAz wrote:
............. if I try to log into the classic “192.xxx.x.x” page and this username and password is not the one I set up while registering my RBR20 to the netgear community;
......I believe you are trying to reach the web GUI on orbilogin.com or 192.168.1.1 (default). To access this page you have to use the username admin and the password that you chose as the administration password when you set up your Orbi the first time.
