powellbc's avatar
powellbc
Cannot Enable Circle, endless loop
I have the issue where enabling Circle on my Orbi System fails, stuck in an endless loop where the iOS app simply tells me the router is compatible. I have seen no answers on this forum or in the kno...
  • FURRYe38's avatar
    Try a factory reset ON the router and setup from scratch using a wired PC and browser. Walk thru the setup wizard and then enable Circle in the routers web page. Save settings and do a full reboot. After the routers back to ready, check the mobile app. Be sure your mobile device is connected to the wifi of the Orbi router.
