KennethP
Apr 27, 2019Aspirant
Cannot enable Circle on my newly RBK40
After successfully installed RBK-40 Orbi Router & Satellite with firmware V2.3.1.48 vir IE on my PC, After I click on parental controls, only redirected to https://www.netgear.com/lpc. Then I tried t...
ekhalil
Apr 28, 2019Master
- Is Orbi set to Router or AP Mode?
- If you are in Router Mode then you should get this page when you click on Parental Control in the advanced settings:
3. Do you see the Parental Control activation switch when you use Orbi app and go to Home >> Settings >> Parental Control?
- KennethPApr 28, 2019Aspirant
The Orbi is in Router Mode.
I can't find Parental Control activation switch in the advanced settings or Orbi app.
If I select Parental Control in advanced settings > Security , it will pop-up a new window and go to below web site.
