orbi-user-1
Jun 30, 2022Follower
Cannot enable remote access
I am having this issue. Cannot enable remote access
michaelkenward
Jul 01, 2022Guru - Experienced User
There can be many different causes behind most problems. There is not much anyone can suggest without further details.
Apart from telling us nothing about the Netgear devices you own, you have not said anything about what you are doing and where things go wrong.
Did you find any of these?
Enabling your router's remote management | Answer | NETGEAR Support
How do I enable remote access on my router using the Nighthawk app? | Answer | NETGEAR Support
What functions can I manage using remote access in the genie mobile app? | Answer | NETGEAR Support
