laotu
Aug 08, 2022Tutor
Cannot factory reset Orbi RBS50 to update firmware because of automatic re-config
Hi, I am updating my Orbi system from 2.7.3.22 to the lastest firmware version 2.7.4.24. The automatic update didn't work. I was able to update the router but the satellites are returning an erro...
- Aug 08, 2022
I am not sure why, but after the last attempt to reset the satellite, it worked and I was able to update the firmware.
That also means, I cannot reproduce the error message.
Thank you for your help!
Aug 08, 2022Guru - Experienced User
What satellites are you using?
Are they V1 or v2?
What firmware version is on them?
Are you manually updating or automatically?
Have you tried logging into the satellites themselves and updating through their gui and not through the routers?
