laotu
Aug 08, 2022Tutor
Cannot factory reset Orbi RBS50 to update firmware because of automatic re-config
Hi, I am updating my Orbi system from 2.7.3.22 to the lastest firmware version 2.7.4.24. The automatic update didn't work. I was able to update the router but the satellites are returning an erro...
- Aug 08, 2022
I am not sure why, but after the last attempt to reset the satellite, it worked and I was able to update the firmware.
That also means, I cannot reproduce the error message.
Thank you for your help!
Aug 08, 2022Guru - Experienced User
What satellites are you using?
Are they V1 or v2?
What firmware version is on them?
Are you manually updating or automatically?
Have you tried logging into the satellites themselves and updating through their gui and not through the routers?
laotu
Aug 08, 2022Tutor
What satellites are you using? RBS50
Are they V1 or v2? V2
What firmware version is on them? 2.7.3.22
Are you manually updating or automatically? automatic update didn't work, so I am trying to do it manual
Have you tried logging into the satellites themselves and updating through their gui and not through the routers? yes, doesn't work, the RBS returns an error message that I got the wrong file
- plemansAug 08, 2022Guru - Experienced User
Are you extracting the file prior to uploading them?
Do you have a screen snip showing what error its giving you?
- laotuAug 08, 2022Tutor
either way, glad you got it fixed!
You might mark it solved since its fixed so others aren't trying to help fix it still 🙂
