althea
Jun 03, 2019Guide
Cannot find Orbi RBK53 with RBSv2 satellites to buy
I'm looking to purchase an Orbi RBK53 system. I notice there is now an RBS53v2 (version 2) so I figured if I should buy that one since it's the latest. I can find nowhere that sells this system that ...
schumaku
Jun 03, 2019Guru - Experienced User
althea wrote:I'm looking to purchase an Orbi RBK53 system. I notice there is now an RBS53v2 (version 2) so I figured if I should buy that one since it's the latest.
Source, reference, ... ? The RBK53 is a kit of three devices, one RBR50, two RBS50. As such, there is no RBS53.
Netgear misleadingly announced "Orbi with Wi-Fi 6 is expected to be available on the Orbi RBK50 series in the second half of 2019."[1], and of course the media picked up and stated "Wi-Fi 6 wireless compatibility will be introduced to Netgear’s RBK50 series of hardware later in 2019. No word on when, or if, the other Mesh products will pick up the upgrade."[2]. Somehow I doubt that existing hardware will be upgradeable to Wi-Fi 6. "Netgear’s Orbi mesh router system is one of our picks for the best wireless routers money can buy, and it’s set to get a lot better, with the company announcing at CES 2019 that it will be releasing a new version of the Orbi RBK50 series with some seriously upgraded features." [3] That sounds more resonable, and that might lead to a v2 product line (and many unhappy customers).
Is this what you are talking of?
- altheaJun 03, 2019GuideThank you. Yes, I meant the RBS50v2 (not RBS53v2).
You can see it mentioned here:
https://wikidevi.com/wiki/Netgear_Orbi_Devices
and talked about here:
https://community.netgear.com/t5/Orbi/Does-the-RBS50v2-satellite-work-well-with-RBR50v1-router-and/td-p/1731313
and seen here:
https://www.google.com/amp/s/www.router-reset.com/reset-manuals/Netgear/Orbi-Satellite-RBS50v2%3famp-content=amp
It popped a few times when I was searching for the RBK53 setup..
