Nick91
Jul 29, 2017Aspirant
Cannot find Orbi Router IP address
I setup a Orbi router (RBR50) and satellite (RBS50) last weekend with my FIOS router. The Orbis system is AP mode and the FIOS wifi is turned off. I'm connecting with ethernet cable from FIOS port to ...
- Jul 30, 2017
It's possible. It's behaving like the FIOS router is blocking the Orbi and refusing to give it an IP address. You should be able to create a static DHCP mapping on the FIOS which maps a specific IP to the Orbi Router based on its MAC address.
If that still doesn't work, you probably should just reset the Orbi and start over.
Nick91
Jul 30, 2017Aspirant
Success!
I set the Orbi router MAC to a static IP (192.168.1.251) in the FIOS router as you suggested and after rebooting the router I can login with both the mobile apps and web browser.
Thanks for all your help ST_SHAW!
st_shaw
Jul 30, 2017Master
You're welcome. I'm glad you got it working.
