JonnieW
Nov 07, 2019Aspirant
Cannot get a teredo IP address
Hi, I’ve been trying to find an answer to this for ages but can’t find anything that explicitly tells me what to do. I’m having issues with party chat on Xbox One. In game it’s telling me my NAT...
JonnieW
Nov 08, 2019Aspirant
Hi,
Xbox is connected wirelessly. uPnP is enabled and no ports are forwarded. I’ve added a reservation for the Xbox One service I found listed. Do I need to do anything on the Xbox?
NAT Type is now Open so hopefully that should be me good to go.
Thanks
Thanks
Nov 08, 2019Guru - Experienced User
If your OPEN now your good. Remember sometimes the networking on the console gets hung up and doesn't clear out on it's own. This can cause NAT status to not work right. Hold the power button the on console until it turns OFF, then back ON usually clears this.
Please mark your thread as solved so others will know.
Enjoy. :smileywink:
JonnieW wrote:
Hi,
Thanks
