skancharla
Jan 18, 2020Tutor
Cannot Get GoGoGate2 To Work With Orbi Mesh (RBK53S)
Just swapped out an Apple router with the Orbi mesh system. My GoGoGate2, which controls my garage doors through an app, doesn't work after setting up the Orbi system?! I see it among my list of co...
- Jan 22, 2020
Hi, I finally got my working. Here are all the things I did (not sure which step did the trick?).
1) Logged in the orbi router Advanced -> Setup -> LAN Setup
Added a reserved address for the GoGoGate2
2) Delete GoGoGate2 device from phone app.
3) Reset GoGoGate2 (button on the face of the device) ...
When setting up WiFi...
- CONFIGURATION MODE: Choose MANUAL.
- ENCRYPTION MODE: Choose the type of encryption used by your Wi-Fi network. To check encryption, please check on the link.
- AUTOMATIC OR STATIC IP: Choose STATIC IP.
- SSID: Set to the name of your Wi-Fi network, where you want to connect Gogogate2.
- WI-FI PASSWORD: Input your Wi-Fi network password.
- IP: Set to the reserved IP in Step 1
- NETMASK: Introduce here the subnet mask (by default 255.255.255.0).
- PRIMARY DNS: Introduce here your router’s IP address (192.168.1.1).
- SECONDARY DNS: Introduce here again your router’s IP address (192.168.1.1).
- GATEWAY: Introduce here again your router’s IP address (192.168.1.1).
4) Finally once you've configured the GoGoGate2, ensure that in device config settings 'Remote Access' is enabled.
These steps worked for me in accessing GoGoGate2 via the Orbi mesh LAN as well as remotely.
G'Luck.
-Sri.
CrimpOn
Jan 18, 2020Guru - Experienced User
When you changed routers, did you set the Orbi WiFi network to the exact same name (SSID) and password as the previous (Apple) router?
skancharla
Jan 18, 2020Tutor
Yes the SSID was identical, all my other devices worked without having to reconnect to WiFi.
-Sri.
-Sri.
- plemansJan 19, 2020Guru - Experienced User
What modem are you using? if you're using a combo device, you're apple might have been in ap mode and you didn't change it with the orbi?
- pfOrbiJan 22, 2020Aspirant
I have the exact same problem after switching from Velop to Orbi, everything else but Gogogate2 works perfectly.
Dont have double NAT, and i have good reception nearby the Gogogate.Hopfully hey come with a firmware that fixes this issue...
- plemansJan 22, 2020Guru - Experienced User
What exact error are you getting?
