skancharla's avatar
Jan 18, 2020
Cannot Get GoGoGate2 To Work With Orbi Mesh (RBK53S)
Just swapped out an Apple router with the Orbi mesh system.  My GoGoGate2, which controls my garage doors through an app, doesn't work after setting up the Orbi system?!  I see it among my list of co...
  • skancharla's avatar
    skancharla
    Jan 22, 2020
    Hi, I finally got my working.  Here are all the things I did (not sure which step did the trick?).
    1) Logged in the orbi router Advanced -> Setup -> LAN Setup
        Added a reserved address for the GoGoGate2
    2) Delete GoGoGate2 device from phone app.
    3) Reset GoGoGate2 (button on the face of the device) ...
        When setting up WiFi...
    1. CONFIGURATION MODE: Choose MANUAL.
    2. ENCRYPTION MODE: Choose the type of encryption used by your Wi-Fi network. To check encryption, please check on the link.
    3. AUTOMATIC OR STATIC IP: Choose STATIC IP.
    4. SSID: Set to the name of your Wi-Fi network, where you want to connect Gogogate2.
    5. WI-FI PASSWORD: Input your Wi-Fi network password.
    6. IP: Set to the reserved IP in Step 1
    7. NETMASK: Introduce here the subnet mask (by default 255.255.255.0).
    8. PRIMARY DNS: Introduce here your router’s IP address (192.168.1.1).
    9. SECONDARY DNS: Introduce here again your router’s IP address (192.168.1.1).
    10. GATEWAY: Introduce here again your router’s IP address (192.168.1.1).
    4) Finally once you've configured the GoGoGate2, ensure that in device config settings 'Remote Access' is enabled.
    These steps worked for me in accessing GoGoGate2 via the Orbi mesh LAN as well as remotely.
    G'Luck.
    -Sri.
