bmng
Dec 15, 2019Aspirant
Cannot get Orbi RBK14 router to recognize ARRIS modem SB8200 DOCSIS 3.1
Orbi router worked well with an Arris DOCSIS 3.0 modem, but when I changed to a new Arris DOCSIS 3.1 modem, model SB8200, I cannot get the Orbi router to connect to the modem and internet. I have tr...
bmng
Yes on the powerup procedures, but I did the setup wizard via my cell phone app.
Dec 15, 2019Guru - Experienced User
Can you use a wired or wireless PC or laptop and connect to the RBRs web page there to walk thru the setup wizard?
Did the phone app give any indication that the RBR was not connected to the modem?
- bmngDec 15, 2019Aspirant
The phone app just lists the internet connection as "offline."
- FURRYe38Dec 15, 2019Guru - Experienced User
What are the RBRs LED colors when you complete the setup?
Please try setting up with a pc and see.
Swap LAN cable between the modem and RBR. CAT 6 cable is recommended.
LED color is solid orange; does not go to blue. Any website or link suggestion on how to do setup via a wired pc?
