HAFrank
Dec 21, 2019Aspirant
Cannot install new firmware on RBR20 Router
When I tried to upgrade my RBR20’s firmware which is currently v2.3.5.26 I got a message that my firmware is “Up to date”, but clearly it is not since I recently got an email message from Netgear tha...
Dec 21, 2019Guru - Experienced User
Did you manually download the FW files from NGs download support site, then unpack the .zip files then use a wired PC connecrted to the RBR and a web browser like FireFox or Opera and use the RBRs web page to update using the downloaded files?
- HAFrankDec 21, 2019Aspirant
Thanks for your response, but your method would not be convenient for me because the computer is too far from the location of the RBR20 Router. I tried to access the firmware update by using the Orbi app on my iPhone, clicking on Settings/Router Settings/Check for Updates. When I do that, it says "No new Firmware is available at this time." But, the email I got from Netgear says there is one available.
- FURRYe38Dec 21, 2019Guru - Experienced User
Youll need to be at the RBR with a PC and browser to do this. I would not attempt this remotely as this might cause problems. If the system is working then you'll be find until you can get on site with the system.
