GeekDadKen
Sep 21, 2018Initiate
Cannot Load Alexa on my Orbi Voice
Added the voice unit to our existing Orbi network. The app recognizes it as a satellite, and when I select it to try at add the Alexa capability, the "Controls" tab that the setup instructions point ...
GeekDadKen
Sep 23, 2018Initiate
Specifically, it says I should be able to select the unit from the Network map, and then select "Controls" to add Alexa. Nothing that says "Controls" shows up for me. Here are screen shots:
schumaku
Sep 24, 2018Guru - Experienced User
ChristineT - another famous one. Remoted to a friends mobile who has a promotion/demo sample of the Obri Voice - and can't find that very same control there either. I simply have no Orbo or Orbi Pro and Orbi Voice (despite several promises...) to test and compare.
