dlong48
May 30, 2020Aspirant
Cannot log in to one particular website from working Orbi LAN
I've had a working Orbi mesh for 2 years. At some point in the last 6? months, I stopped being able to log into https://www.ring.com. I can reach all other websites fine but, for ring.com specifica...
dlong48
May 31, 2020Aspirant
Screenshot attached. It doesn't seem to be sensitive to the chosen password. And, yes, I've power cycled the router. Thanks for any help, folks.
dlong48
Jun 01, 2020Aspirant
Also tried downgrading to V2.3.5.30. And, to clarify something I wrote earlier, I don't have a Cable router--it's just a modem (Netgear CM1000 running latest firmware).
- FURRYe38Jun 01, 2020Guru - Experienced User
Orbi would not be inhibiting a web site unless you set some parental controls.
If you factory reset the RBR and setup from scratch, clear ALL browser caches and try different browsers, the web site should work find. If not, you might contact the web sites admin to see if there is any thing they require to use and log in to there site.
dlong48 wrote:Also tried downgrading to V2.3.5.30. And, to clarify something I wrote earlier, I don't have a Cable router--it's just a modem (Netgear CM1000 running latest firmware).
- dlong48Jun 01, 2020Aspirant
Factory reset and restoring from the backed up config didn't help. Note that I can reach ring.com fine; it's just preventing me from logging in after I enter my username and password. It's an https site so I may not be able to glean much from packet tracing. Any other suggestions? Thanks.
- Mikey94025Jun 02, 2020Hero
How very mysterious! Do you have VPN enabled (Advanced tab... Advanced Setup... VPN Service)?
Something on the Ring side seems to be blocking your client IP only when it is handled by the Orbi network. I found this Ring Community conversation that mentions a similar error message: https://community.ring.com/t5/Ring-App/406-Not-Acceptable/m-p/38181. In it they recommend calling Ring support at one of the phone numbers listed here: https://support.ring.com/hc/en-us/articles/213608406.
