sandman512
May 03, 2020Apprentice
Cannot log into orbi login via http://www.orbilogin.com/index.htm
SO, I am trying to log into my ORBI system via http://www.orbilogin.com/index.htm. After entering my credentials, it says Please wait a moment and hangs up there. Any thoughts? Thanks.
- May 04, 2020
UPDATE: So, just turned the ROUTER off/on and was able to succesfully log in. Thank you.
May 03, 2020Guru - Experienced User
Be sure to clear all browser caches.
Try a different browser, IE11, Firefox or Opera...
Does 192.168.1.1 do the same thing?
sandman512 wrote:SO, I am trying to log into my ORBI system via http://www.orbilogin.com/index.htm.
