sandman512's avatar
sandman512
Apprentice
May 02, 2020
Cannot log into orbi login via http://www.orbilogin.com/index.htm
SO, I am trying to log into my ORBI system via http://www.orbilogin.com/index.htm. After entering my credentials, it says Please wait a moment and hangs up there.  Any thoughts?  Thanks.
  • sandman512's avatar
    sandman512
    May 04, 2020
    UPDATE:  So, just turned the ROUTER off/on and was able to succesfully log in.  Thank you.
