johnniej
Jan 19, 2019Tutor
Cannot log into RBK50 router using MS Edge browser
I cannot log into my router with orbilogin.com when I use MS Edge browser.
Works fine with Chrome or if I use Internet Explorer.
I have started to use the Edge browser and kind of like it except...
- Jan 27, 2019
Sorry. Here's the link from the previous post.
michaelkenward
Jan 20, 2019Guru - Experienced User
While randomousity is on to something about the IP address, I fear that correcting the network configuration may not make Edge work.
Browser makers all round are tightening up on their security to prevent naughty things from attacking us. Sadly, in the process they also break things that we do want to work.
Using MS Edge, Cannot connect to router, please re... - NETGEAR Communities
If IrvSp has problems, there isn't much hope for the rest of us.
IrvSp
Jan 20, 2019Master
Yup, as I stated in the link, there is a WORK-AROUND, not really a fix. See https://answers.microsoft.com/en-us/edge/forum/all/microsoft-edge-browser-cant-access-network-ip/1e7d32c7-f8ed-431d-9b64-ed822dd28717, April 25th, 2018 enter in the thead.
- michaelkenwardJan 20, 2019Guru - Experienced User
Workaround not needed here. But no harm in using it.
IrvSp wrote:
...not really a fix.
It is a toss up as to who should fix it. Microsoft or Netgear.
If all other browsers can handle this, I'd finger the Edge developers. After all Netgear is only one victim of a disease that seems to have hit many other services.
It might help if, like some other browsers, Edge threw up a warning to users that also allowed them to cast their fate to the wind and login anyway.
But Netgear could also help by implementing more recent addressing, including the much demanded https.
- IrvSpJan 20, 2019Master
michaelkenward, personally, I'd blame MS more than anyone.
Why? IE works but not Edge? Apparently MS changed the handling or requirement for Trusted Sites it seems in Edge. No warning either or advice on what to do?
MS has a habit of doing what it wants sometimes. Thinking they know better than you what you want. They also at times have and will make it hard for competitor's products. Some changes that can cripple or make competitor products less desireable. Some of it is understandable. It is their product that has been 'reproduced', as in the Office applications. Simple changes or additions make the competing products less desireable and the they scramble to catch up. Perfectly legal. Including applications within Windows, EU didn't think so with some 'parts', did they. OS 'wars', locking down PC makers with restrictive licenses. To get the cheapest per copy license Windows had to be put on every PC sold. Oh, you wanted another OS, no problem, you get both Windows and the one you want (sometimes not installed even) and of course the higher price to include the other OS.
At least A/V's and Firewalls either 'know about' or allow you to specify you LAN IP Address (and even on first attempt to use it ask for permission) so why aren't PRIVATE IP Address ranges pre-trusted (maybe during install of first use rather than 'rejecting' them outright with NO warning)?
If Edge has as many followers/users as MS thinks/hopes, and many Web sites with problems don't you think MS would have notified or posts somewhere a warning? They did for SMB1, didn't they, directing you to contact your h/w vendor if you have a problem?
You really have to ask why does IE work but not Edge? Same s/w platform, same s/w vendor. We know the web site didn't change? More than why? The question should be what made this happen?
Why Microsoft? Because it writes Edge.
Just because it gets things right in one area does not absolve it from responsibility for the stuff it gets wrong.
If Microsoft Word, for example, were perfect, would that mean that I should not blame it for defects in Microsoft Outlook?
