johnniej
Jan 19, 2019Tutor
Cannot log into RBK50 router using MS Edge browser
I cannot log into my router with orbilogin.com when I use MS Edge browser.
Works fine with Chrome or if I use Internet Explorer.
I have started to use the Edge browser and kind of like it except...
- Jan 27, 2019
Sorry. Here's the link from the previous post.
michaelkenward
Jan 20, 2019Guru - Experienced User
IrvSp wrote:
michaelkenward, personally, I'd blame MS more than anyone.
Why? IE works but not Edge?
Why Microsoft? Because it writes Edge.
Just because it gets things right in one area does not absolve it from responsibility for the stuff it gets wrong.
If Microsoft Word, for example, were perfect, would that mean that I should not blame it for defects in Microsoft Outlook?
johnniej
Jan 27, 2019Tutor
- IrvSpJan 27, 2019Master
johnniej , posted the same here (and forgot about it too) under https://community.netgear.com/t5/Nighthawk-WiFi-Routers/Using-MS-Edge-Cannot-connect-to-router-please-read/m-p/1689346 as a new thread. Maybe it should be a 'sticky'?
- johnniejJan 27, 2019Tutor
Thank you IrvSp.
That's where I got the link from but got lost in everything I was doing and couldn't remember where I got the link from.
Thanks again for your help.
