ShannonReiter's avatar
May 06, 2019
Cannot log-into RBR50 Router after initial set-up
I just bought and attempted set-up a new RBR50 router, so far the wireless network is working flawlessly and I've been able to get my satellite set up and connected as well. However, when I try to lo...
  • FURRYe38's avatar
    May 06, 2019
    What browser are you using?
    The best method to set up the Orbi is wired PC/Laptop and broswer and walk thru the setup wizard. Write down all important information during this setup process. After it sets up and you have input a PW for the admin account, you should be able to access the routers web page again using same PW.
