CT72
Apr 04, 2018Aspirant
Cannot log into RBR50
I have my new system set up, and the wifi is working wonderfully. However, I cannot log into the router at all. I get to the login page, but when I enter the default username & passwords "admin" & ...
Apr 04, 2018Guru - Experienced User
Orbi systems don't use default Passwords anymore. When you set up the router, you should have walked thru the setup wizard and it will ask you to input a new admin PW. Use this PW to access the routers web page.
CT72
Hi & Thank you, FURRYe38.
I recall that step & thought the password being changed was the one for the wifi network. I cliked "don't change" & kept going. I'll try to run setup on the app again & see what happens...
- FURRYe38Apr 04, 2018Guru - Experienced User
Theres two actions in the wizard, PW input for the Admin log in account and then PW for the wifi SSID.
Keep us posted.
