CT72
Apr 04, 2018Aspirant
Cannot log into RBR50
I have my new system set up, and the wifi is working wonderfully. However, I cannot log into the router at all. I get to the login page, but when I enter the default username & passwords "admin" & ...
CT72
Hi & Thank you, FURRYe38.
I recall that step & thought the password being changed was the one for the wifi network. I cliked "don't change" & kept going. I'll try to run setup on the app again & see what happens...
Apr 04, 2018Guru - Experienced User
Theres two actions in the wizard, PW input for the Admin log in account and then PW for the wifi SSID.
Keep us posted.
