BrandonE
Mar 21, 2019Initiate
Cannot login to Orbi as admin
I am unable to login to my Orbi using the admin password. It doesn't matter if I use the mobile app or website. I've never changed the admin password from the default. I also tried deleting / re-i...
Mar 21, 2019Guru - Experienced User
Factory reset the RBR router and wire connect a PC to the RBR and walk thru the setup wizard. Be sure to write down all information for safe keeping and use later on.
