1midniterider
Dec 18, 2017Guide
Cannot play media recorded on DVR (Verizon FIOS)
I have a two unit setup. I have setup the RBR50 as the primary router. The Verizon G1100 acts as a bridge to the coax connected STBs. The two are connected via the LAN ports. When connect my Android p...
DarrenM
Dec 20, 2017Sr. NETGEAR Moderator
Have you bridged the modem or have the orbi unit in AP mode?
DarrenM
- jmschnur923Dec 20, 2017Luminary
I use the Orbi in AP mode with the WiFi of the fios router off to good effect.
- 1midniteriderDec 21, 2017Guide
The Fios router is bridged. Well at least I believe it is. When I'm not on my home wifi I can access the DVR movies successfully. The Orbi is in router mode.
