Reproman
Sep 26, 2022Aspirant
Cannot Put Outdoor Satellite Into Extender Mode
I have tried several times to get my RBS50Y into extender mode to use with my new Orbi WiFi 6 network by following the published instructions. Tried multiple resets and power cycling, but I am unabl...
CrimpOn
Sep 26, 2022Guru - Experienced User
Are these the instructions: https://www.downloads.netgear.com/files/GDC/RBS50Y/RBS50Y_QSG_EN.pdf
Can you please describe what happens at step 6?
Reproman
Thanks for your reply. Yes, these are the instructions that I am using. At step 6, I get a solid white light, followed by a brief solid blue light, followed by a pulsing white light (never see pulsing white and blue). Eventually it turns solid blue, but I cannot see the NETGEAR_EXT network on my phone or computer and the RBS50Y continues to appear as a satellite on my Orbi WiFi 5 network. Very frustrating.
