Reproman
Sep 26, 2022Aspirant
Cannot Put Outdoor Satellite Into Extender Mode
I have tried several times to get my RBS50Y into extender mode to use with my new Orbi WiFi 6 network by following the published instructions. Tried multiple resets and power cycling, but I am unabl...
CrimpOn
Sep 26, 2022Guru - Experienced User
KevinLiT wrote:
The RBS50Y is not compatible with our Orbi Wifi 6 Mesh system.
Extender Mode is the key factor. Notice this section of the Installation Instructions referenced above:
Ever since the RBS50Y came out, there were clearly two "modes" :
- Orbi Satellite
- WiFi Extender
Previously, the Product Sheet proudly claimed that the RBS50Y was "compatible with any WiFi router."
However, today, the Product Data sheet no longer includes that statement and clearly states that the RBS50Y is not compatible with the Orbi AX products.
Something is rotten (and not in Denmark).
Reproman
Thanks for your reply. I am aware the the RBS50Y is not compatible with the Orbi WiFi 5 network, which is why I am trying to put it into extender mode. I have followed these instructions numerous times with several resets, including the 30-30-30 reset. I can never get it to broadcast the NETGEAR_EXT SSID to complete the process.
- FURRYe38Sep 26, 2022Guru - Experienced User
So to get Extender mode on the RBSY, first the Extender Mode firmware has to be loaded on the RBSY while it's connected to a Orbi compatible system. Once the RBSY has the extender mode FW loaded on it, then it could be connected to a Orbi AX system. It won't fully integrate like the RBS do however will run like a NG extender and provide wifi coverage. I see that Extender mode FW is only available for the RBS50Y v2. v1 only has support or Orbi home systems and Orbi Pro systems.
- RepromanSep 26, 2022Aspirant
Thanks for your reply. Yes, I had read that the Extender Mode firmware limitation existed for the RBS50Y version 1, but unfortunately not until I had already switched over to the Orbi 6 and couldn’t get the extender mode up and running on the RBS50Y. I was hoping that someone might have come up with a workaround to allow for RBS50Y extender use in this situation. But it seems not to be the case. More planned obsolescence.
- CrimpOnSep 26, 2022Guru - Experienced User
Yes, if what you have is an RBS50Yv1, then you are well and truly screwed.
- It cannot work as an AX satellite because the RBS50Y WiFi radio chips are not compatible with the AX radio chips. and
- It cannot work as a regular WiFi Extender because Netgear did not make the v2 firmware backward compatible with the v1 model.
It's too tall and too light for a doorstop.
