hensed
Jan 01, 2018Tutor
Cannot reach WAN ports from LAN
Hi all, I have been seaching thru the forums but have not found a discussion that is exactly my issue. I have setup an Orbi router and satellite and everything is working great...except for one t...
TheEther
Jan 01, 2018Guru
It's possible that the Orbi doesn't support NAT loopback. NAT loopback is required in order to use the WAN IP from the local network.
If I am correct, then it's kinda odd, because Netgear's other routers, like the Nighthawk line do support NAT loopback.
