User2928474
Jul 20, 2020Follower
Cannot register product
Hello, I have purchased a Telstra Wi-Fi Extender Max (Model: EXS6190). I cannot register the product on Netgear, and I cannot contact support via the support portal because I have not registered the...
Jul 20, 2020Guru - Experienced User
It seems like that device was made by netgear and old to telstra.
you'd want to contact telstra for support.
Is there an issue you're having other than registering it?
maybe we can help with it.
